walterwitt
🔌 New-ish
A local Mesh Radio Enthusiast group started buying cells from me, and one of the big requests they have is for button top cells. But I don't think they're worth 2-3x the cost, so I looked into spot welding my own button tops on my existing cells. @BlueSwordM then told me that it's be great if they where made of pure Nickel instead of Steel for better conductivity, which he later revealed was actually @BatteryMooch 's Idea. So after not finding any satisfactory results on AliExpress, and mostly not wanting to wait so long, I came up with a 3D printed Jig to turn 6mm Nickel Strip into professional looking button tops. Here's some pictures
It uses 4mm dowel pins that press the nickel strip into a PETG die. It has 4 slots, but the 4th I use as an indexing point so it really just punches 3 at a time, but I end up with quite consistent 9mm spaced 2mm tall button tops. I then cut them out as shown above, put them in a little 3D printed centering Jig, and spot weld them to some EVE 35Vs
After all that to make them clean enough to sell, I hole punch some Fish Paper, stick it on, trim to size then heat shrink.
I only had black heat shrink lol.
But yeah, feel free to ask questions, I'm better at sharing pics than thoughts as you can see.
