Okay, so here's something I figured out that I think needs to be shared.
So, if you know your max speed, and gear ratio, you can plug it in here:
cyclingroad.com
Input your gear ratio and top speed and you can figure out your cadence. Probably only works for mid-drives.
I use uh..DigiHD to calculate top speed. (gps speed app)
All you do is play with the cadence until it aligns with your top speed. Or thereabouts.
For example, I plugged in the BBS02 I'm running, and it's 75, with a 53-15 gear ratio, which is pretty sad.
The same setup with a BBS03 gave me 115 rpm.
The BBS02 is probably damaged. It's had things..done to it.
Yep, that's about what it adds up to. 24 mph.
And noisy. It probably got cooked.
Same setup with a BBS03 and 58-15 did 37 mph.
Bicycle Gear Ratio, Cadence, and Speed Calculator - Cycling Road
To use the bicycle gear ratios calculator, follow this step. Choose the size of your bike wheel and the size of your tires, then input your preferred cadence,
