Only from version v20.1C.6-update-2 is it possible to perform an alternative torque sensor calibration on the display. Find the description in the manuals.Hi,
I’m trying to find the reason why my TSDZ2B is limited to a max speed of 40 km/h. I haven’t changed any settings; it just happened one day after doing some maintenance on the bike.
After checking various potential causes, I’m left with one: a decalibrated torque sensor. I have a few questions regarding this:
1. What are the typical symptoms of torque sensor issues?
2. Can I calibrate it using the 850C display?
3. Can I perform this procedure on the 850C with Emmebrusa OSF without connecting to the Java configurator? (My controller is damaged and is not being detected by the ST-Link v2).
thank you
Previous versions require a reflash, after entering the offset and max values in the JavaConfigurator.
