likeicare
I have an ANCHEER Rover L and got an e 10 code, the only thing that does does not work is pedal assist and throttle. After trouble shooting I believe it's the wire harnees connection. I also have the AHCHEER Rover H, so I swapped the wire and everyting is fine.
I need to replace my wire connector harness and can't seem to find the right wiring combination, the wire brand is LinkWE
this is the main long wire - Controller Main Input: 9-pin Male (Black) and 3-pin Female Front/rear Light Display (Yellow)
These are the 4 other wires Connection: Throttle Connection: 6-pin Male (Black) Brakes: Two 2-pin female (Red) 5-pin female connector (green)
I also attached my motor which is a model: KD-JDW145F and my HUB
