Voultepsis
π New-ish
Hello everyone,
I am the owner of a SUNRA ROBO-S 3kW electric scooter equipped with two independent 72V battery packs, each containing its own BMS.
After approximately 12,500 km of use, both battery packs started showing abnormal behaviour. The dashboard frequently displays flashing 0% battery indications and significant differences in reported state of charge despite similar measured battery voltages.
I have been trying to understand the communication between the scooter and the battery BMS systems.
So far I have:
Does anyone have information regarding the communication protocol used by the SUNRA ROBO-S battery system?
Has anyone successfully identified whether the system uses RS485, UART, CAN bus, or another proprietary protocol?
Has anyone managed to use alternative batteries or replace the original battery packs while maintaining normal scooter operation?
I have attached a detailed report describing the battery issues, communication concerns, measurements and the technical difficulties encountered while trying to diagnose the system.
Any information from SUNRA owners, battery specialists, reverse engineers or BMS experts would be greatly appreciated.
Thank you.
So far I have:
- Measured voltages on the communication connector.
- Investigated the wiring between battery and scooter.
- Used an RS485-USB interface.
- Performed oscilloscope measurements on the communication lines.
- Attempted to identify the protocol used between the batteries and the scooter.
Thank you.
