Tabless design cylindrical cells tests
I really like these comparisons.
One question arises though:
How well do these cells balance in a battery pack?
I remember my unpleasant experience with the Samsung 30Q which was quite a remarkable cell otherwise...
That is correct. The 65P leaved the 60P in the dust. It has even a lower IR. Significant lower.
Do you think the 60P compares to the RH60 ? Btw, have you tested the RH60 already ? I thought the RH60 would be the new budget 6Ah 50S killer at an affordable price. The 65P is still very expensive (however, it seems like it's the perfect cell ever produced yet so worth it)
Basically, most modern all-tab cells designs tend to be very consistent and because of better thermal performance and internal consistency, balancing performance should be better as well.
60P is definitelly more powerful than RH60, it is close to RS60.
However, if I had to choose between thr Linkdata 60P and the RH60, I'd pick the RH60.
I need opinion and suggestions.
Example: when selecting 21700, 30ACC, all visible models, Voltage over time graph, then this gives a crowded graph with intersecting lines. Identifying the various colors<=>models becomes difficult.
Suggestion: in the moving overlay, sort the entries from top to bottom according to voltages for that particular timestamp
@ZEUS-FL and and myself are now waiting for the samples to be delivered. The Amprius 60Q should arrive first, because availability of the GreatPower 60Q is a bit of a problem right now. Anyway we should have the results by the end of the month. At the same time, I'm also waiting for Tenpower 60XG samples.
