Connect PAS sensor to LSW1728-2-1E wired for torque
smitel
New here
Is it possible to connect a PAS Sensor and possibly throttle to a LSW17288-2-1E that's wired for torque?
I was hoping to trace the wires to the PCB and potentially change some pin-assignment in GitHub - EBiCS/EBiCS_Firmware: Free FOC firmware for Lishui E-Bike-Controllers, but it's very potted inside.
Torque sensor measurements:
Red: ~14V
Green: 3.3V
Black: GND
Yellow: 3.3V
White: 0V
I just noticed the green pin for the torque is called "TA" which is the same as my original controller.
Should I just be able to find a 5V source for the PAS sensor and then wire the signal pin to the green pin of the torque connector?
Does anybody know what the ADI pin should mean?
How would I wire the throttle?
Is this great controller available again? From Phoebe Liu EV Parts it's not delivered to Europe sadly. :-(
This is a controller of the "new generation":
The throttle has to be connected to the Pin "SP", you have to remove the potting to solder the wires in.
The PAS signal would have to be connected to TA1, it only works if the analogue signal for the torque is about 0.7V at switching on the bike and then has a higher value during rinding, just as it would be expected with the torquesensor installed.
There is a very long discussion about this special controller at the German Pedelecforum.
The throttle has to be connected to the Pin "SP", you have to remove the potting to solver the wires in.
Ahh, the "ADI" from the photo corresponds with the "AD1" from your pinout. Thank you for the useful information!
Mine died just a few days ago. I hoped on just changing the FET's but there's a lot of black smelly stuff and a few additional holes in the PCB.
I had a spare one but I killed the UART today using the electrolytic while cutting the display cable all at once. It's running fine but no comm.
This one again or digging into VESC? Or a Bafang?
I saw in the German forum, that you have used the EBiCS firmware.
If you want to go with a torque sensor and a commercial display, I can't recommend a VESC.
The Lishui EBiCS firmware is the most mature from the various EBiCS ports. The Bafang port for the hubmotor controller is on a quite early stage, all the improvement we have added for the middrives are not included in the master branch for the CR101 controller.
You can still get the Lishui 12FET on alibaba.com, on AliExpress they are not available for shipping to Germany any more :(
Lishui has several high power controller meanwhile.
I was able to test them, thanks to EBS Heidelberg, they have a different current calibration to measure higher phase currents, but EBiCS runs on them properly, you just have to set the right calibration factor in the config.h
