Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello ES! We could use some help to get us past the finish line on building the new knowledgebase for the forum.
Hi i have a few jbs bms i have registered and logged into the app, thd older version show parameter options i can change but the latest one does not give me any options in parameters to change it?
I've had these BMS apps where you can only change settings with an admin login or something. If overkill solar supports that BMS it is a way better app. Worth a try to see if the parameters come up then.
