jerseyebiker
🔌 New-ish
- Joined
- Oct 30, 2009
- Messages
- 37
Hi guys!
**STOP**
**STOP**
**READ THIS WARNING FIRST**
**IF YOU BUY ONE OF THESE UNITS ONLINE AND YOU ARE NOT A MECHANIC BUYER BEWARE**
**WHEN I RECEIVED THIS UNIT WITHIN THE FIRST 3 MILES THE FRONT WHEEL BECAME LOOSE. BOTH AXEL NUTS COULD BE SPUN BY HAND. THE LEFT SIDE REAR AXEL NUT COULD BE SPUN BY HAND. I CHECKED EVERY BOLT AFTER THIS HAPPENED. THE TOP TREE CLAMP ON THE FORKS WAS BARELY ON. ALL OF THE TREE CLAMPS ON THE TUBES HOLDING THE BARS ARE BARELY TIGHT. ONE OF THE BOLTS HOLDING THE HEADSET TUBE WAS LOOSE. **
I received my Z4pro a few days back. I bought it on Amazon. I have clocked about 200 miles on it so far. I am breaking it in for Delivery duty. The box delivered in good condition. The scooter delivered in good visual condition.
Issues I had out of the box:
-LOOSE FRONT AND REAR WHEEL IN THE FIRST 10 MILES.**Fixed omg wt..
-LOOSE TREE CLAMP BOLTS ALL OVER THE PLACE.**Fixed
-LOOSE HEADSET TUBE BOLT.**Fixed
-THE FRONT AND REAR SUSPENSION HAVE ZERO DAMPENING AT ALL. NONE. NADA. ZILCH....ALL SPRING. Its like riding a pogo stick with wheels.**Working on it
-The battery door has no seal. Its open to the elements. Dirt from your feet and water can freely enter the battery box. Its PG rating is NADA.**Working on it
-Know issue with the battery shaking inside the box. **Fixed
-When the forks go to full extension they smash on a metal stop. Its loud and it happens ALL THE TIME. Common with cheap bin scooter forks. They will 100% destroy themselves in no time. The closest 2 dealers told me they all do it. I am sourcing better forks currently. Wish me luck!**Working on it
-It shipped with a short twist throttle. Why anyone would install a twist grip throttle of any kind on a scooter blows my mind.*Working on it
-Breaks not set up correctly. Super common but still had to be fixed.**Fixed
-3 power modes = 2 with nothing and all gas from 80% to 100% and sport mode being more linear.
-Break line is rubbing the headset tub.**Fixed
-Extended all the way, the bar height is way to low for anyone over 5ft 10. I had to install a set of rider bars.
Positive stuffs:
-Plenty of spring, maybee to much for a 235# rider. Way to much for the 165# rider who cruises hyper scooters who rode it. Like WAY to much lol. The spring rate will handle adding a seat and delivery rack without issue imo.
-More then enough power. In single and dual motor mode it performs fantastic. Tons of torque. 230# standing all the way forward and the front tire screeches on take off easily. Given the box type frame I cant imagine giving this thing more power then it has.
-13 inch tires are very stable for a scooter. The tread pattern is fantastic for a vehicle that lives on gravel roads and dirty shoulders these tires are great. They are loud but I cant hear squad with my helmet on anyways
-The brakes are insanely grippy. Stopping power is many times what it needs to be. I can monkey grip the brakes and lock up both wheels no problem on pavement at any speed. It has DOT3 fluid breaks!
-The lights are great. The headlights are very bright. The break lights are tiny but bright. The blinkers are well done and easy to see. The side bar lights pretty bright. You can never say "I didnt see you.". Its impossible. The thing looks like a UFO going down the street. The lights are so over the top everyone is looking at me instead of the road.
-The kick stand is not bad. All metal. Good return spring rate.
-Adjustable handle bar high.
Battery Range with a 230# 6ft 1 inch tall rider:
-Unit has 3 power modes and 3 gears. Gear 1 has a speed limit of 18mph.
-In Eco mode in gear 1 with both motors on I was able to get about 25 miles of range with a 230# rider and still had 20% battery left over. Lots of starts and stops. Frequently giving it the beans. Long sections of fairly loose sand. Lots of slow technical stuff with stop and go.
-In Eco mode, single motor in gear 1 on the street taking it easy off the line with an average speed of 15 mph on pretty flat roads the unit went flat in 34 miles.
My Review:
The assembly was absolute trash. I mean WHO THE HELL IS PUTTING THESE THINGS TOGETHER? FIRE THAT GUY AND THEN FIRE THE GUY WORKING NEXT TO HIM. FIGURE IT OUT. I am an industrial tech/mechanic who has teched thousands of machines for more then 25 years and this is without a doubt the absolute most unsafe unit I have ever seen out of the box. I have seen so many quality issues from China over the years in the e-vehicle realm. Thats an old hat but this is HUMAN error. Sure the unit has some material problems but its also a 2200$ bin scooter so you get bin scooter problems like the suspension. It has 13 inch tires. Its super stable for a stand up scooter. The controls are above average for a bin scooter. Great power.
=Would I buy it again? Nope! By the time I fix the suspension Its going to be a 3k+$ scooter. I still have to figure out a seat and rack. The factory seat option blocks the battery door and is a non starter so I will have to build my own. While I absolutely cant say enough good things about the 13 inch tires I could have gone with a premium 11 or 12 inch tire scooter for what its going to cost me to make this one ready for delivery duty. It is NOT SAFE to leave this unit in any amount of rain. The battery compartment is open to the electrons. The battery door does not seal. Its a tub with no drain. It will be a rolling bathtub in seconds. Way to much bullsnot for 2200$. Last product I buy from this company. The unit was so unsafe.
**STOP**
**STOP**
Positive stuffs:
My Review:
