I thought, why should a very important part of the body freeze?
And I found a piece of sheepskin. Call of the Wild:
I love the inner tube seat! I'm going to try an inner tube for a head rest in my recumbent.By the way, before becoming a sofa, it was an ordinary moped:
The ICE of a serial hybrid runs at a constant rpm....starting from certain battery size/range, a series hybrid transmission starts getting highly tempting, if only there were compact and most importantly - silent generators that can be engaged and disengaged on demand...
Good plan but NB the numbers of that aerofoil at the bottom of your last picture.Hi,I want to make a battery box NOT in the form of one and a large,and split into three pieces,they will be 110mm thick each,in order for it to have an aerodynamic shape,I put plastic on the front,for this made protrusions in the box (material aluminum heat-treated).
Hello friend. You touched upon a very important topic of tires and tubes, at first glance it seems like a trifle, but in fact it is very important.Tubes ? This is the old company now you pissed me off I thought using 26 inch lime tubes extra thick was the ticket. ? And you had to use it here or you come by so I got the thin tubes I guess Sun tube slime or something then tube. Both of the slime tubes plug up on the presta Valve and on the Schrader valve they have ripped right under the valves down don't feel more secure the tailwind of this still being over again slime tubes.
Sorry for jumping in and thank you but nobody wants a flat especially on a rear motor
No spring can replace a chamber filled with air, this is ideal!I love the inner tube seat! I'm going to try an inner tube for a head rest in my recumbent.
I am very far from aerodynamic air resistance, so I am doubly grateful for the proposals coming from those who are knowledgeable in this.Good plan but NB the numbers of that aerofoil at the bottom of your last picture.
You want that plastic to form half an ellipse, where the whole ellipse would have a 3 to 1 ratio.
Then you want that sharp trailing edge at the back, or as close as you can get to it, while chopping the end off square.
But at the end of the day; read my previous post and go (silent) Serial Hybrid with a direct coupling top gear.
Hi Philip, sorry about the delay, I don't get onto the forum as often as I would like. Yes,it is great to encounter a fellow couch lover.Super, you did it very beautifully!
I didn't experiment with the frame length, but did it on what I already had, you know, I decided that it was easier to change my riding skills than the frame, and as a result, I learned to ride quite well on a reclining couch.
Yes, there are another 40 kg of batteries for the complete set in addition to the 20 that are already in the frame, they will be removable, each of their 3 batteries is provided with independent control electronics and will be connected in parallel.
In general, I'm glad that another sofa lover has been discovered.
I looked at your previous device, it has a backrest for a sitting person, but not a reclining one, why am I focusing on this? Because good aerodynamics on such devices are obtained when the air envelops the body, but does not rest against it, so even if we sit low, but at the same time our body is like a brick for the wind, the aerodynamics are still bad.
After all, we make such sofas not for the sake of relaxing on them, but to save battery.
I posted above the battery capacity consumption at decent speeds, this is 70-80 km / h on average, the consumption on the sofa is 30-32 watt.h / km. But on a seated moped, the same route and at such speeds consumes 44-46 watt.h / km, the difference is noticeable.
About "instability at high speed", everything is exactly the opposite, starting from 60 km/h the sofa just acquires excellent stability, where the excessive steering damper from the friction of the tire on the asphalt at low speeds becomes a plus at high speed, the sofa holds the course direction perfectly. This was literally a revelation for me.
And yes, it also takes corners very well with a decent load on the front wheel.
Thanks Pilip. Don't worry, if you spend the next 20 years refining your bike, it too will look more finished.Wow, it looks like business class compared to my 3rd class!
On your website I saw an option with protective arcs in case of a fall, that's really cool!
Hi Anthony, Thanks. I don't want to take over Pilip's post so I've put my reply over in my Build threadTig, whatever you're spending on aesthetic design and photography is worth every penny! Can you say more about those parts of the journey?
Everything related to recumpent is very exclusive, so write here everything you have, it will be very interesting.Hi Anthony, Thanks. I don't want to take over Pilip's post so I've put my reply over in my Build thread
ok, thanks Pilip, here we go..Tig, whatever you're spending on aesthetic design and photography is worth every penny! Can you say more about those parts of the journey?
Earlier Electrom:
Unrelated Earthglider:
