dangerzone
Jeremy Harris said:dangerzone said:I was at the AERO Expo 2010 in Freidrichshafen, Germany this April and there was a good idea for long range flight of electric airplanes. Since about 5kW to 12kW of electric power is enough for sustainable flight of UL aircraft then such an electric generator that could produce it would be great for long trips. Just put the generator on the plane or the co-pilot's seat and the range of the electric airplane can go for a few thousands of kilometers if a good fuel consumption is achieved... Some Simonini 2 stroke engines weight around 9 to 12 kg and consume 5l of gasoline for producing 12kW of shaft power, now the only problem would be converting that shaft power to electric power with minimal losses. Whoever comes with a solution might make a lot of money producing such small electric generators, imagine having them in any electric vehicle or airplane as a 'plan B' when something happens to the battery or the EV/EA runs out of 'juice'...
A few years ago I came up with something similar, but using direct drive from a 120cc paramotor engine fitted with a concentric electric boost motor for take off and climb, a bit like the configuration the Honda hybrid system uses. We didn't bother to build it as the total weight was greater than a conventional propulsion system and offered no real advantages. The problem with hybrid aircraft is the low ratio of peak to average power; average power is typically 50 to 70% of peak power, whereas for a car average power is often only 15% to 20% of peak power, making a hybrid solution more viable. Slow flying ultralights are probably the only case where it might just be viable, as they tend to have a higher ratio of peak to average power than other aircraft types, maybe around 2:1.
Jeremy
Have you seen the electric paramotors nowadays..? Some of them have quite a performance with some 10kW or even up to 20kW, better than a 250ccm ICE.
