7circle said:Whats happened with the production Run of the big Colossus?
Is it on another thread?
I'm needing at least 4 of them.
If some-one has too many and not needing them let me know please.
Also has drive board bee built to push them hard?
I'll start a thread on this crazy Buggy we plane to convert to hybrid. 300HP = 100ICE + 100ICE + (25PM+25PM+25PM+25PM)
7C
SplinterOz said:Guys I have been glad to help. Now lets see if I can get up and running first
Wow awesome very awesome!!! What is the skirt bearing number???HAL9000v2.0 said:Hi guys,
just few words.. the motor is completly redesigned. The skirt bearing is smaller dia, there is mechanical adjustment of hall position without opening the motor, universal steel mount that can be welded/screwed is added, ( it can be detached and the motor mount is like old one). I have redesigned every part of the motor with none or minor change of production cost. I expect the price will be around old one but the motor will be much better. The shaft will be with key, any other rises price of the shaft. We will also make some standard sprockets to match the shaft.
Samples will be shipped before Chinese new year so I think we are ahead of the schedule...
Test paltform is in the garage and waiting , 36FET controller is on surgical table and he will get some 4110s and some 100V caps..
AussieJester said:SplinterOz said:Guys I have been glad to help. Now lets see if I can get up and running first
May i ask what controller you will use?
KiM
SplinterOz said:AussieJester said:SplinterOz said:Guys I have been glad to help. Now lets see if I can get up and running first
KiM
I am using a 24fet controller constructed by Steveo on the forum. It is an Infineon based controller like the Keywin version. This one should be good for 200amps for extended periods.
So far so good, BUT I have yet to run the motor under load.
I will be turning down the controller to ensure that all is ok before I try a full power run.
Check out my website for more detail.
Arlo1 said:... What is the skirt bearing number???
