Keep in mind that in these cheap common controller designs (whcih go all the way up to Sabvoton, Kelly, MQCON, and beyond), the powerstage doesn't do current sharing very well between FETs. So the higher you go, the more likely there is to be a difference between one fet and the next in the same phase, great enough to bring that FET past it's abilty to handle it, and POW, then all the current flows thru the other FET(s) in that leg of the phase, and POW (POW POW) etc.
So pushing things harder than the max a trusted vendor recommends is probably bad for reliability.
(pushing things even that hard may affect reliability--any form of "hotrodding" almost always decreases reliability, though you can get lucky for a long time...right up until you don't.
