Waynemarlow
Is there any supplier of cells with tags attached, for the two small 14S2P packs I want to make it just seems not worth while to purchase a spot welder ?
Thanks
Thanks
Punx0r said:Individual tagged cells allow construction of a pack that is soldered together without the difficulty or danger or soldering directly to the cells. This is the route I went. It's not as neat as a spot-welded pack, and a little taller overall, due to the thickness of the copper bus wires rather than nickel strip, but it saves buying a spot-welder.
It will work OK, but if you want to keep the soldering points on the cells to a minimum ( thats "zero") , then use the tagged cells that this thread is discussing !mitchdes said:I am trying to keep the number of soldering points on each cell to a minimum.
Is there any reason why connecting the 18650 cells in this zig-zag pattern won't work?
14s4p arrangement - connected with 4mm tinned copper braid rated at 30amps. Cells are all hot glued together.
