Ok guys, I'm officially on my way to joining the 19" wheel club.
Bought the following:
- HS4080 hub motor
Pro-Wheel 19x1.4 36-hole rim in silver (model 19-TTRSIR)
CST 19x2.0 tire
19x2.0 tube
18/19" rim tape
18” rim strip (plan on using the rim tape but bought this just in case and for checking fit before lacing)
Now all I need is spokes and nipples. Is everyone going through JRH, or is there another source I should be looking into as well?
Also, has anyone here laced up a 4080(or 4065) to a Prowheel 19x1.4? If so, can you kindly give me the spoke length you used and if you recommend that size (or if yours were too long how short you would go)?
I'm thinking with all these wheel builds we should create a chart that we can share showing what motor, rim, spokes (including length), nipples, etc. were used in the build.
For example:
MOTOR__________= Crystalyte HS4080
RIM______________= Pro-Wheel 19x1.4 36-hole
NIPPLES__________= ?
WASHERS_________= ?
SPOKES___________= ?
SPOKE LENGTH____= ?
PATTERN__________= 2-cross
