Rix
100 TW
quite a difference in foot print GC, Running a 2.5 or 3.0 x 26 would show a little bit closer in foot print with your tires. I take your studded tire is for the snow, how does it work for you?
Rick
Rick
Observator said:Hello. Just went thru the thread. The pictures are very help full when judging size, thank you all for them. I am contemplating going from a 26" crazy bob to a 19" MC wheel. In all honesty I'm not that happy about going to a smaller size, but space constraints are forcing my hand. The wheel is to be used in a swingarm meant for 24" bicycle tries. And i thought if I'm going to the trouble of lacing a wheel, now is the time to do it right.
However after researching this subject some I am in a bind. I don't have allot of funds to splurge on this. And from what i can tell going to a MC setup really ads up in cost. I'm also worried i might end up with a less than expected performance. The motor in questions is a 8t MAC. I have been running at around 1600 wats peak, and don't expect to change that as i need the poor guy to survive. Am i in a to low power spectrum to make MC/Moped tire/rims viable?
I have seen a guy on here running Moto tires on regular BMX wheels, would this be a viable option? I need to limit expense any way i can, but still get a solid setup. With that bit of rambling back story here goes some questions:
Anyone have a good source in EU for any of the following:
19" Rim
Spokes for 19" rim to lace up a MAC motor
Decent tire in 19" preferable not wider that 2.5" inflated.
Any input of thoughts on the above is greatly appreciated.
johnrobholmes said:I have two 7t MAC motors in 17" rims right now. Both on the front of really heavy trikes. Stellar combination for mid 20s speed on 36v and gobs of torque. I would agree that a 17 is a better choice than a 19 for an 8t MAC, but with a skinny moped tire the 19 could be light as well.
Observator said:Thank you for your input, i do understand the benefit of a lower rotational due to the limited power spectrum of my motor. However i don't want to change my front wheel aswell, mainly due to cost. Since my front is a 26" running crazy bob's from Schwalbe its a rather tall tire. And i fear the bikes geometry would be suffering from the steering angle altercation going to such a small tire as 17" on the back. An other reason for wanting the downgrade in circumference to be as little as possible, while still not exceeding the 24" size swingarm can accept. Is i don't want to change my battery setup, and my topspeed now running 12s is right around 50km/h. I don't need higher top speed, but I'm not to keen on lowering it either. I see that you both suggested going to a 17", is there any particular reason 18" isn't mentioned?
Regarding the 17" 7t MAC's i am to very interested in seeing pictures. If possible with a 26" MTB wheel for size comparison would be great! I'm also curious if you had to do anything special to the MAC's spoke flange in order for it to accept MC wheel spokes?
Observator said:Thank you for the pictures, ascetically it doesn't look bad.
kdee122 said:I must be one of the only people running 21's front and rear. OD is only 2mm larger than my old 26 x 2.4 downhill tires. Weight is up big time but I did not measure it back to back.
Running Kenda downhill tires my tire life was only 150 to 200km and I was always worried about pinch flats. So far I have about 450km on the motorcycletires and I really like them. Solid and safe at 80kph. I will try some 2ply tires in future to get the weight down.
Rix said:Who makes 2 ply 21" MC tires? I can only find 4 ply, but my knowledge and ability to search for stuff on the net is way way limited. Rick
Ch00paKabrA said:Rix said:Who makes 2 ply 21" MC tires? I can only find 4 ply, but my knowledge and ability to search for stuff on the net is way way limited. Rick
The front IRC GP1 tires are 2.75 x 21 inches and are 2 ply. The weight is 6.18 lbs
but they are still a rather expensive tire compared to the Shinkos at $55.00 (but many bicycle tires are more expensive).
Here's a link: https://www.denniskirk.com/irc/front-gp-1-dual-sport-2-75-21-tire.p540956.prd/540956.sku
Hope it helps.
'Cal
2007blueprius said:http://e-bike-diffusion.com/index.php?module=top_ventes
http://www.ebay.com/itm/131133926151?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.shinkotireusa.com/tire/705-series
this is what I came up with, looks like most 21 inch rims are 1.6 wide, others are kind of hard to come by, but in 1.6 according to the shinko web only a few knobby tires are available, the 705 is the thinnest road like tire, I'm kindof looking to build a commuter and since I have to spoke a wheel anyway than why not except for cost obviously,
overall diameter is listed at 27.36, bit shy of 29 but than again not sure my 29 is really a 29, close enough I guess, I am tempted to this setup for a rear wheel, leave an original 29 for the front? with a with at 3.54, likely I have do tweak the frame, that was in the works anyway, weight? I'm sure it would be quite a bit well unless you all know a better option for me or a reason why not?, I may just order these, I should get my donor bike Friday and a new 1000w hub
http://www.ebay.com/itm/PRO-WHEEL-FRONT-RIM-21-KSYBK-36H-1-6-x21-GENERATION-III-YAMAHA-KAWASAKI-SUZUKI-/281299402762?pt=Motorcycles_Parts_Accessories&hash=item417ec0400a&vxp=mtr this is another option for a rim the Italian is steel, might just be too much, but this is a 1.6 wide, I may be able to fit that tire but is it a bad idea?
George
