Powervelocity.com
Thanks. What about michelin, pirelli, IRC, vee rubber that you mentioned earlier?
Are they really lighter in the same sizes (17-3.0 19-2.50-2.75)? Any experience with them? I already have the rims and I like the size combo, just need to come up with a bit lighter tires.
Thanks.
Thanks.
efMX Trials Electric Freeride said:maybe consider a matching 17" front wheel if you are mostly road riding..
that should be lighter than the lager diameter 19" wheel..
and you may consider a bit narrower tires..
17x2.5 or 17x2.75 would be lighter than 17x3 tire..
Powervelocity.com said:I've been running Shinkos 17-3.0 in the rear and 19-2.75 in the front and they have performed great. However, they do seem to add quite a weight, so I was looking maybe for a less beefy alternative, maybe something in 2 ply department. Has anyone used some lighter MC tires and can recommend good front-rear combos in these sizes?
