Rix
100 TW
Ch00paKabrA said:Rix said:Mr Lowbank said:I have a question. what tyre levers do people carry in the camel back with the MC Setup. Or is the theory you won't need any.
Thats the best part, you don't need to carry in any tire levers as long as your rear PSI is above 20. I haven't pinch flatted an MC rear yet and I put my machines into fairly isolated rocky locations and time and time again, been fine. You will see.![]()
Rick
It's been a decade since I've done it but I used to be able to do doubles at the MX track. If the rim/tire/tube combo can withstand that (and triples that others could do) There is no way you are going to get a pinch flat. I also used to ride out in the desert and dry lake beds when I lived in California and never had a flat either.
+1 Ch00paKabrA, Its been closer to 2.5 decades since I raced Enduro and Desert in Idaho, I can tell you that blowing through a rock infested sandwashes at over 80MPH on a geared up 1991 KTM 540 DXC, I didn't pinch flat on that stuff either, even though I dented rims all day long bouncing off that shit. And I would venture to guess that the 2.75x19 SR241 would be harder to pinch flat than a Bridgestone M59 80/100x21 which I have ran on front of several dirt bikes over the years, and I was running those tires at 14PSI and only pinch flatted when I was center punch lava rock because the SR241 has more rubber and taller profile than the M59. Granted tires on the year are subjected to a lot more abuse, but we are talking ebike applications and not 60+HP dirt bikes weighing anywhere from twice to 3 times as much as an Ebike.
