Rix
100 TW
wonder if this is common of MC rims but see below it has 2 valve holes almost across from each other
Missed this,
Blue Prius, the reason our rim has "2 Valve holes" is one is for a bead lock, which you don't need to run as long as your keep your tire @ or above 20psi. Yah the 21" MC rim is comparable to the 26 MTB rim the same as the 19MC rim is to the 24MTB. I know I have raved about the SR241, but I would consider running a Vee Rubber VRM 308F 2.75-21 or a VRM 021 2.75-21 on your wheel. I don't know how much weight savings you will get, but sectional widths of these tires will be about 1/2" narrower than the SR 241.
