Ellectrico
🔋 Established
- Joined
- Aug 10, 2019
- Messages
- 53
Hello everyone, just got a new shipment of batteries for you guys.
All the batteries are new and unused, and they don't come with a charger. The specs are below:
Full description:
Price: $195
Condition: New, never used
Manufacturer: SCUD
Enclosure and protection: Hard industrial plastic, scratch and impact resistant. Honeycomb cell holders and anti-vibration silicone between cells to reduce damage overtime. Water resistant silicone insulation. Metal screws holding together the cell holders and hard plastic shell) Also has a connector for battery meter.
Length : 9.87 inches ( 9 and 14/16 or 25.08 cm)
Height: 5.62 inches ( 5 and 10/16 or 14.28 cm)
Width: 2.81 inches ( 2 13/16 or 7.13 cm)
Weight: 8.7lbs
Voltage: 48v
Capacity: 19.2aH
BMS: 60a (Low Voltage/Overcharge/Temperature/Current output and Short Circuit protection, power equalization output)
Discharge rate: 60 amps continuous 90 peak (920w continuous or 1500w peak)
Max Charge rate: 2.5a
Limited Charging Voltage: 54.6V
Charging time: 5-6 hours
Cycle life: ~800-1200 full charge and discharge cycles
Configuration: 13 series 6 parallel
Cell type: lg-18650-mh1 3200mah
Amount of cells: 78
Chemistry: Lithium - Ion
Connectors: xt60 + 2 pin for battery a meter
Does not come with a charger
Availability wise, we have around 25 at this moment so hurry up. It is possible that we will get more in the future but it's not certain.
Better prices for 3 and up. Can fit up to 4 in one box.
Let me know if you have any questions.
Full description:
Price: $195
Manufacturer: SCUD
Weight: 8.7lbs
Voltage: 48v
Capacity: 19.2aH
Amount of cells: 78
