OlderGiantFan
🚴♂️ Mega poster
I bought the bike for it's suspension only, the 2.5 knobbies will be removed and replaced with 2" (50mm) road tires. It's interesting this business of air pressures and rolling resistance, it turns out I've been wrong and running mine way too high. I've been running at the limit of the tire specs, which are basically just a legal requirement imposed on manufacturers and calculated as 50% of the pressure that will burst the tire off the rim. They have no connection to actual rider speed and comfort.Knobbies are like Road-driving with Super Swampers.
Tipped off, I went to this site and used the calculator to figure what I should be running
Tire Pressure Calculator
Finally a tire pressure calculator based on real-road rolling resistance measurements. On real roads—rather than on a steel drum in the lab—supple high-performance tires work best at considerably lower pressures than most cyclists are used to. Lower pressures roll as fast or faster, while...
I dropped pressure on one bike to the recommended and went for a ride, it was much plusher, no jittering, and my average speed was essentially the same or better. That was on my 2002 26" Yukon running tires allowing 80 PSI, I was at 80, then dropped to 57. A substantial decrease. I did some research and uncovered that the Higher Pressure Meme came from university studies conducted in smooth hallways, not on real roads where even the best surface is covered in tiny bumps. So many misconceptions out there in the World, and we can tend to cling to them out of habit.
Here is one of those old studies that got it wrong.
