hi, I am new on here so hi all,
I am making plans to build a bike with a mid drive, BBSHD because of its reputation for reliability.
I am not asking for links to components, just opinions on the frame and my intended use for it.
basic info:
I would have fat wheels (26x4) on a rigid fork, suspended seatpost, an internal geared hub in the rear, and a single speed chain with a tensioner.
Alternatively 7-8 speed HG cassette rearranged/spaced out so that the important gears are in proper chainline.
rider weight 65kg.
this is the frame I chose, for under 300dollars :
unknown manufacture. fits at least a 26x4 inch tire, standard seat post diameter. I pefer the regular shaped tubes for easy mounting of clamps etc. reinforcement plate where down tube meets head tube.
the dealer says it is "fat bike steel", other than that there is no other info about the grade
intended purpose:
exploring rough forest roads
no jumping, mostly just rugged forest paths (bumpy dirt/gravel, few rocks sticking out), long level sections with mud/ loose dirt, which
I think the fat tires and suspension seatpost would do well on.
relatively slow riding (my gearing will be for slow climbing rather than speed)
terrain is hilly, not very steep, long climbs (definitely not like hardcore steep mtb trails),
for whoever sees and reads this, my question is: by looking at the frame,"unknown grade steel", do you see any problems / weakspots with it? assuming it is the cheapest grade steel acceptable for bike frames, can you see it holding to the level of stress I described? (rider weight is 65kg + some stuff on a rack, at least a
15ah battery mounted on the downtube inside triangle). do the chainstays look strong enough to handle the motor torquing? I would run it at 48volt, stock setup (no over powering or anything like that)
I dont know how much can someone experienced tell just from pictures and the info I provided, but please share your thoughts
basic info:
rider weight 65kg.
intended purpose:
