docnjoj
1 GW
Glad you got home. If the motor turns, there is a good chance all the gears are intact. Clutches? Bearings. I used the Allen screw in the screw hole like D8veh showed and it worked. Could not open the motor with a 2x4 pry bar with holes cut and screwed in. Hammer and Allen screw method worked. Be careful to mount the Allen screw with washers as his photo showed. I used a longer Allen screw at first and broke off 2 of them.
otherDoc
otherDoc
