How2 said:Errrr... uhhhh... so this "filter wrap" is something you will cover your Currie motor with to prevent moisture and debris from getting into the motor after holes are drilled into the cover? Am I tracking with you?
YES!!!docnjoj said:Does it lower the noise level????
EcoForumZ said:*** Two day test results ***
Bike 2008 Ezip trailz mountain bike
36v 10ah lifePO4 battery pack
Tested twice over two days in hot weather to get a base line and averages
Day 1 94 degrees, Day 2 92 degrees
Total distance 12.98 miles
No peddling at all not even on starts
UncleRoy said:EcoForumZ said:*** Two day test results ***
I went looking, but could not find your weight. It would help to know that in judging your results.
I'm 230 and it has had a HUGE BIG FAT impact on my mileage.
docnjoj said:Hey EcoForumz! Have U put any holez in Ur motor yet? I cant tell from the pics.
otherDoc
OzzyU812 said:Just got one. Plan on making mechanical mods. A friend at http://www.motoredbikes.com suggested this forum for electrical mods, so I joined. I didn't where you say hi here, so um HI!
paultrafalgar said:Are you going to keep the second motor? I only ask because someone on this forum has joined two of those motors to drive one bike. If memory serves it was very successful at running the motors cooler. Do a search for two or dual motors.
Edit: Found it here:
http://www.endless-sphere.com/forums/viewtopic.php?t=4936#p73522
