hi dogman,
i think you might be right. my setting the gearing is usually 22T , 26inch wheel. Maybe it should be 24t or 28t will be better. i ever run cyclone on the tallest gearing, motor do get hot too. i feel cyclone motor is small in size, alittle look cramp in size that gets the heat very fast. maybe i do run alot on drag speed from a dead stop (some times). there is some difficulties in replace hall senor in cyclone, i will choose to left it there in my box.
cyclone can be improve one day for a better performance motor. hope to see them in the coming years. yes, the chain kit is really powerful,, alot powerful then my 48v 1000watts kit in pick up speed. top speed is also faster 67km/h on 48v, compare hub is 51km/h on 48v. but i will choose hub as a best choice. - best thing about hub.. easy to replace hall sensor for anyone. i can use the tallest gearing say 32t, but the top speed is lower. :|
cheers,
kentlim
cheers,
kentlim
