Hi Joz
I generally dont ride the KMX in the rain, the snow was as wet as I have got with it to date, you can get the fenders for the front as well from KMX, they are a little pricey though, but then getting soaked is no fun either.
The KMX do suffer a little with corrosion on some of the bolts, I have found lashings of wd40 or acf50 work really well in keeping it nice and shiny and corrosion free.
Back to you DC went out in the garage and bolted the controller to the bike, the 20A one, will take it for a test run later maybe if the weather holds if not I will try and get out inbetween the showers and try it, I still think 20A would be enough.
Ill try it and see, if it works and doesnt cut out we should be ok, good to go, wish I had a drain brain as my watts up meter wont work at 72V, need to get me a version 2 meter some day.
fingers crossed x I still think your batts will be ok if you keep it to 25A max keep that safe margin in place, we dont want to melt your batteries, mine are easier to get at!!
It more like electric boat weather at the moment though
Cheers
Knoxie
