22 inch tyre?
datahar
Cumbria, UK
Just when I had gotten comfortable, I found something else to be a total noob over
Tyre sizes...
as an introduction my brain is firmly coded to use millimetres and all this inch business thoroughly confuses me
I have an all in one electric wheel, so I am stuck to rim size, the rim has printed on it 22x1.75
so I picked up a inner tube sized 22 x 1.5 - 2.125 so far so good, that fit fine (or alteast it went on :wink: )
I also picked up a tyre 22 X 1/1/2 figuring the 1/4" of an inch difference was the width and I'd be able to get away with it?
but the rim just falls straight through this tyre, so obviously I didn't get away with it...
What sort of tyres could I be looking out for? 22x1.75 seems to be firmly not on the internet... : -(
will get a pic up later when at home...
Oddly enough, 22"X1-3/4" and 22"x1.75" are actualy diffrent rim sizes. It comes up in other rim sizes too. The short explination is if your tire uses decimals in the size, you can't use a tire who's size is in fractions. They are different sizes of rims.
A longer and better explination can be found on the Late, Great Shelden Brown's web site: http://sheldonbrown.com/tire-sizing.html
Here's one source for your tire. Just the first hit on google. http://www.everybicycletire.com/Shopping/pc-3175-16-22-x-175-courtesy-tire-457.aspx
ooh thanks!
I read this page but missed the significance of the separation between decimal and fraction : -(
so if I stick to fraction could I get anything between 22x1.57 to 22x2.15?
because if so that opens up my options greatly! (I'm being hampered by living on the wrong side of the pond at the moment :D )
To be honest, I'd never heard of a 22" tire, but a little research found what you probably need for your rim.
Strange how they have different diameters and all called 22". 22x1.75 is 457mm. others are 490mm.
http://www.everybicycletire.com/Shopping/c-16-22-inch.aspx?resetfilters=true
datahar said:
ooh thanks!
Well, decimal. fractions are the ones with the "/", but you got it. And if you have all those choices, you're on the right side of the pond.
:p yes my brain can get confused with 50/50, I will end up saying one but meaning the other!
Slow delay but...
Success! Now I just need to figure out why it doesn't go :p
