Russell
DahonElectric said:Hi Russell,
Ahhh okay.. I'm starting to see the light here with some of the confusion here. I suppose you do not own a Cycle Analyst?!? You do know that you can use the CA to do the throttle controlling for you automatically?
Did you know that the Cycle Analyst comes with a rudimentary cruise control function built into the box?? They call it the "limiting features" (page 12) and you also have the ability to tune the feedback loop of this cruise control to maintain the transition between on and off smoothly (page 13). So in effect, you can turn a rather dumb ebike into something similar to a Bionx system. It's actually pretty cool to feel the motor turning on and off, to maintain a fixed cruising speed with you pedaling with it the same time. I also limited the current draw too, so it climbs rather anemically without sucking a lot of amps (current limit feature on CA) and it helps conserve the battery usage quite a bit. Downside is that, it pretty much limits your bike to doing a certain speed. You need to restore those limits to higher values if you want the beast of the 9C to return and I find them tiring after doing a while. I much prefer Bionx assist 1 to 4 with a 1 button touch. I wish Justin would incorporate a "Cruise Control" function separate from the current limiting features and can only be engaged with a touch of a switch. The kill switch for this throttle on control would be the brake lever. JVBIKE sells the Bionx brake sensor.
Battery consumption is not a function of speed though. It's a function of acceleration and hill climbing and is controlled by the current draw of a set system, because once you achieve your cruising speed, current draw would be minimal right. Yes, you can somewhat control the throttle to minimize current draw, but if a computer does this for you like the Cycle Analyst or the Bionx, wouldn't that be even better?
I agree with you that the Bionx system is expensive and it doesn't have the guts to go head to head with more powerful motors out there, but I am actually looking into expanding the capacity of my Bionx system to include one of those LIFEPO4 24V 12ah battery ebike.ca has for sale. All I have to do is disable the regenerative braking so it doesn't charge the battery and then I'm set. Part of it is inspired from Denis who also owns the same bike as I do. But learning from his experience, I'm trying it on my out of warranty Bionx battery that I think is no longer 8ah -- probably closer to 6ah. Still 18ah in a nice light package is going to be cool!
Thanks for the reply Russ..
DE.
I have a Watt's-Up meter mounted on my handlebars to monitor power consumed. Again I don't need a CA to limit current because I use 15A controllers and limit current with the throttle. Because I use a trigger throttle I am able to finely adjust power on a continuous basis and after a while just like driving a car it become second nature. I use the motors for assistance so I have no need for high current. My legs can provide very good torque for acceleration and up hills I gear down and pedal vigorously with the motor providing a nice boost.
I of course was being simplistic when I said battery consumption was all about SPEED but that's the bottom-line; how fast you get up to SPEED (accelerate), your SPEED up a hill and the SPEED you run on the flats, so YES it's all about SPEED. Again it's very simple...when my average trip speed is high I use more power. If I want to use less power I go slower. I have a record of every ride I do and it's pretty clear cut...and of course it makes perfect sense.
In the end it's all about personal preference so if you're happy with the BionX that's great but for me it offers no real advantage. As I said one day I may try the kit and find I like it best of all but for now I like the set-up I have and am not done experimenting.
-R
