Okay, so i'm about to order 2 identical 1500w 48v hub motor kits, one for rear, one for the front (obviously) from ebay. This means 2x 1500w 48v controllers, 2x 1500w 48v hub motors, 2x displays, 2x 20ah 48v batterys, and 2x throttles.
Now, in my small and simplistic mind accompanied by my basic soldering skills, i have figured i can use only one throttle for both wheels (just splitting the cables from the throttle really).
However, i'm wondering what would be the best solution;
one throttle - one display - 2x controllers - 2x batterys - 2x hub motors
Or
One throttle - 2x displays - 2x controllers - 2x batterys - 2x hub motors?
(each controller have each their fitting battery, to gain maximal effect without frying anything by pushing the power needed to power 2 wheels through one controller as well as providing longer battery life.)
I want to have just one display showing on my handlebar, as it wouldn't look really good with 2 displays showing the same speed and a load of wires around.
(I am not going to use the pedal assist AT ALL, will probably remove the chain and pedals entirely and replace them with foot-pegs).
Advice is greatly appreciated!!
Or
