I've done that air-letting-out after first inflation, and sometimes doing that a few times to settle the tube into place. Talcum powder inside the tire to let everything slide as needed during installation is something else I've done, but I don't always do that. Neither one would've helped in the case I had of bigger-than-would-fit tube, as there was literally inches of overlap on the circumference of the tube.
I haven't pulled on the tire or anythign to settle things; I wonder if it would make a differnece to other installations (it wouldnt' have to this one).
Regarding the battery box, I spent a while sorting thru aluminum box parts from rackmount stuff, as well as a pile of old rackmount networking equipment, and I think I found the box I will use for now. It does not fit in the frame but it does fit where the other broken/wiggly plastic pod is right now, and will hold the whole mass much closer to the center of bike mass, and hold it solidly.
It is steel rather than aluminum, and the box probably weighs twice as much as the plastic one, but is still light. It will better protect the battery in the event of a crash than the palstic one, too, although being under the seat it is unlikely to get any impact or sliding damage anyway. There may be enough room in it for the charger, too, but I am not sure that I want to build that into the bike as I rarely need to charge up on a ride.
Gotta wash it out and remove the standoffs and such inside, mark and drill bolt points for the frame, and then it'll be ready to pack the battery into and bolt on.
Another find while I was digging thru the boards in the biggest networking rackmount box (which I had hoped to cut down to one that would fit, but it is way way too heavy, with thick steel): DC-DC converters! Some are 12V at 15A, which should take care of my lighting needs, if they will run off the pack.
There are two power supplies in one of these boxes, and one in each of the others, for a total of 9 of these PSUs.
Each one has four DC-DC units, two 12V and two 5V.
The PSU spec is 5VDC at 50A, 12V at 15A, and -12V at 2.5A.
All DC-DCs are by Lorain, "Megahertz Power" Reliance Comm/Tec. Both 5V units are p/n LM260-CV, one 12V unit is LM261-CU and the other is LM261-CY. I can't find a spec sheet on the web for any of them, so I don't know which 12V unit is 15A and which is 2.5A, but I can probably determine that by experimentation.
The 5V units are thus 25A each. I did find a note on an ebay sale for a similar unit that a 5VDC supply is needed to turn them on, using the Gate input as marked on the case. Haven't tested any yet.
But all of them are "300VDC" input. The actual voltage coming in can't be any higher than 200VDC, because that's what the caps are rated, and probalby not even 170VDC because it's just full-wave-rectified/filtered 115VAC running it.
All those ratings are presumably with sufficient heatsinking and airflow only, becuase there is a MASSIVE heavy heatsink on these things, and a tray with four fans at the bottom of the main chassis.
I separated the electronics from the chassis parts, so now I have this pile of aluminum trays that should be useful for something, possibly for smaller battery boxes I can layer together to make mini-packs I can stick in whatever spot on the bike I have available.
There's also another case I almost decided to use, whcih is a dead 450W hot-swappable PSU for a different network rack unit (it has two; I haven't tested the other one). Might be interesting to fix it, though, as it probably has PFC, as it also has a power meter on it for AC input level. Might be useful for bench testing and such; might even work as a DC-DC from pack voltages, but it is quite large.
I got a copule of other PSUs out of the other chassis, which if they work shoudl be useful for 12V supplies to run things like the Venom RC charger.
This is some of the other chassis and boxes I considered using or modifying for use, but decided not to use yet, including a couple of those PSUs above:
