Take a look at these:
http://www.curtisinst.com/index.cfm?fuseaction=cProducts.dspProductCategory&catID=8
Curtis makes several AC induction motor controllers, but most of them are lower voltage than your motor is likely wound for. If you rewound the motor, it may work nicely with one of these.
I have seen some industrial motor speed controls on eBay for cheap in the past. These are usually called VFAC drives. These may be rated for the voltages the motor is designed for. They typically use a 480vac input, some are made for 240 or 120 vac input. Like a switching power supply, I susupect many of these would work fine on DC input if the voltage is in the right range.
Most induction motor controllers would also require a shaft encoder of some sort to send rpm data back to the controller.
