kmxtornado
Albeit slow, I'm still learning so please bare with me for this newb question.
I currently have a 36v 10ah battery and am looking for an upgrade (yes, already). I was looking through the Tech and FAQ's section for some info and stumbled upon the power calculator. Since volt x amp = watts, the 36v 20ah battery puts out significantly more watts than a 48v 10ah battery. Is there any reason I would want to go from a 36v 10ah battery to a 48v 10ah battery if my 36v 20ah battery was my alternative? No, right (other than price since a 36v 20ah battery is lots more $$$$ than a 48v 10ah one)? I should see significantly more improvement in the 36v 20ah battery.
If not these two types of batteries, what would you recommend as an upgrade worth spending money on that's still a LiFePo4 battery? Perhaps a 36v 16ah battery? Please keep in mind that I have the Mini Might kit: https://hightekbikes.com/shop/index...oducts_id=10&zenid=36uk0batfffcv5e5e4ns088au4 which is 350w nominal and 500w peak. Does that mean that if I have any wattage over 500w, it would be a waste and unused since the motor's capped at that level? Not sure what that means exactly. Please help clarify.
My 2 year warranty is only good for a 36v battery so I'd like to stick with that voltage. I guess that's another reason to get a 36v battery. My current controller is the upgraded 20ah one.
Please share your thoughts and recommendations. Thanks!
