50 Things You'll Never Get to do w. an Electric Motorcycle
Kent
Vermont, USA
by Nigel Morris
Renew Economy
Most of you are painfully aware that I have spent the last two years riding a 100% electric motorcycle, in my case a 2010 Zero DS.
It’s true, I’m a little obsessed and not just because I’ve always liked riding bikes. For me, the real revelation is that an electric motorcycle can not only provide all the excitement of riding, but perhaps more excitingly I can now see that their applicability as a household energy storage appliance is inevitable.
As much as I love my 2010 model, since riding the latest models I have been looking for excuses and ways to get a new one. Electric vehicles are advancing at incredible speed and in just a few short years since mine was made the performance, range and sophistication of their bikes has been astounding.
It was therefore somewhat ironic and fateful that I flew over the handlebars of my 2010 model, courtesy of a nice old man who wasn’t paying attention to what he was doing. I suspect that I may be Australia’s inaugural electric motorcycle crash test dummy.
Luckily, I bounce pretty well for an old bloke although my joints and tendons keep reminding me that I’m not 16 years old anymore and that bitumen isn’t very bouncy.
The bike was less fortunate although it was an excellent real world test of its strength and the crash safety of an electric vehicle. It didn’t spontaneously combust, electrocute me or anyone else. In fact, it came away pretty well apart from from some cosmetic damage. The post crash assessment revealed that the frame and running gear were all perfect and the battery pack and electric drive train all tested just fine. I was concerned that the forces may had caused some internal stress on the battery cell terminations and other electrical connections but these things really are built strongly. Zero’s investment in design and testing just passed a real world proof of concept test. I’ve almost completed the cosmetic repairs and she’s already back on the road.
Having said this, there is nothing like fate to create opportunity and excuses for change and it forced me to make two decisions. The first predictable outcome is that I am now the very proud owner of a brand new 2014 Zero DS 11.4. I’ll warn you now that you will be hearing a lot more about my new ride in due course.
The second and perhaps even more profound change is that I am giving up on petrol powered bikes and selling my other bike, a quite rare and much loved Moto Guzzi V11 Rosso Mandello. After more than three decades of riding and owning more than forty different petrol powered motorcycles I have decided to sell my sole remaining one.
That’s right, I’m going 100% pure electric.
As a consequence, my neighbours are now intimately familiar with the sounds of air compressors, metal polishers and the late night clanging of tools. Although the old girl has very low mileage, the prospect of a sale warranted a meticulous overhaul and she has undergone a frame up restoration to bring back her former glory.
I have spent the better part of 100 hours on the job already and it was around 3am one morning that something suddenly struck me. By converting to 100% electric there are some things that I will quite possibly never ever have to do again when it comes to owning and maintaining a motorcycle. I had just spent a full nine and a half hours sanding, grinding and polishing the entire stainless steel and carbon fibre exhaust system and was covered from head to foot in an unfathomably sticky combination of wax and cotton residue from the polishing wheels. It’s a job that I will be very happy to not ever do again. Ever.
On the flipside, I got to use some tools and skills that I’ve had since I first learned a trade thirty years ago. I even used the opportunity to teach my two young boys a a few of the finer points of mechanical restoration, cunningly disguised as a punishment for beating the crap out of each other one too many times. I still read restoration and vintage bike magazines on a daily basis and am in awe of the craftsmanship required so it was with a tinge of genuine sadness that I realised that these old skills are in my case, less relevant.
However, now I just wish the Guzzi was done but the list of tiny job’s just goes on and on so for fun, I kept a list of all the jobs I had done that are pretty typical of an overhaul that I will never have to do on an electric motorcycle.
Fit new seals to petrol tank cap
Replace overflow lines to petrol tank
Refit petrol tank
Refurbish fuel lines
Clean and descale fuel taps
Replace fuel filter
Check fuel pump operation
Prime fuel system
Clean air filter
Clean air filter box
Refit air filter box
Check and refit fuel injection intakes
Check and adjust throttle linkages
De-scale exhaust system
Polish stainless header pipes
Re fit exhaust system
Replace heat affected rubber isolators
Polish and repair exhaust hangers
Fit new exhaust gaskets
Fit new exhaust studs
Check and adjust valves
Clean and refit rocker covers
Fit new rocker gaskets
Fit new spark plugs
Fit new oil filter
Check and clean spark plug leads
Clean and check sump bolts
Clean and check oil cooler
Check HT coils
Drain and replace gearbox oil
Drain and replace engine oil
Drain and replace bevel gear oil
Clean and adjust drive system
Replace oil cooler breather
Reconnect all fuel and air lines
Check clutch wear
Check gearbox wear and gaskets
Check pushrod condition
Replace clutch fluid
Bleed hydraulic clutch lines
Lubricate and clean clutch lever
Clean and refit gear selection lever and linkages
Check starter motor
Check and torque set almost 400 bolt tensions
Check and maintain around forty bearings
Clean and lubricate several hundred parts
Lubricate tachometer cable
Restore and polish generator cover
Clean and restore alternator
Repair busted alternator cover bolt
Of course, this list doesn’t include the potential for a full engine, gearbox or drive train system rebuild in the event of a fault or major overhaul, which would add a list of around 200-300 more jobs I reckon, plus thousands of dollars. For comparison, here are the things I would have to do with an electric motorcycle, most of which would also be done on an internal combustion engine.
Check around fifty bolt tensions
Check and maintain two motor bearings
Check and replace drive belt
Check and replace brake pads
Replace and bleed brake fluid
Check and replace suspension fluids
Check and replace wheel bearings
Conduct computer analysis of performance and errors
Clean and lubricate around thirty parts
Check tyre pressures
As an old friend said to me “Geeze Nige, if you don’t get to fiddle with all these things and do all this cool mechanical stuff, doesn’t that sort of take the fun out of it?” The answer to me was pretty clear. “Nope. It just means I can spend more time working on aesthetics, electronic performance enhancements, bodywork modifications and riding.”
More fun, less work.
Source: Solar Business Services. Reproduced with permission.
RenewEconomy Free Daily Newsletter
I found the above to be a great reminder of all the things that we used to do for our ice machines-and took for granted-that we no longer have to do.
Glad to hear you got through that ok. Enjoy the new ride.
Some biker is going to tell you, " he'd have heard you coming on a Harley" but I know that guy was both blind and deaf. Just have to try to be ready for it when they screw you like that.
