As long as I'm "burning" the electrons I've harvested from my private property, and not burning any fossil fuel, I refuse to feel very guilty about any speed I can muster above 33 MPH. Right, now, I can't get above that, so the issue is moot, for now
But, with a bit of luck, some hard work, and with advice and help from this august forum, I shall soon achive truly neck breaking speeds!
I agree with everything said about fossil fuel and the urge to get there fast... the two are totally incompatible, given the socio/political/environmental/scientific milliu (bad situation) in which we find ourselves.
But hey, since when have we shrunk from a challenge? I produced 970 KWH from my PV array this month, but I still had to buy 30 or 40 KWH from Edison... pisses me off! I don't have the funds to expand my solar array, I'll have to come up with another way to gen up those electrons to charge my vehicles! And thankfully, the Web is like the biggest junkyard I've ever had the joy of exploring...!
So what about this....
A new type of engine has been invented that will efficiently use low pressure gas (2 to 20lb of steam, compressed air, any vapor under pressure) to produce mechanical energy, and hence electricity. http://www.greensteamengine.com/ You may have seen this already. The problem is... how to get that sunshine into gas-under-pressure. Maybe these folks in Alaska have a solution... http://www.yourownpower.com/
They use their 165 degree F hot springs water to flash R-134 refrigerant from liquid to vapor to drive a big turbine. R-134 has a very low flash temperature. They are producing Megawatts with 480 gpm of 165 degree F hot water.
I have maybe, a thousand sq ft of sunny roof. I think its possible to get 5 hp (a mere 3.73 KW) out of that.... not completely sure yet, but it certainly sounds like a fun next project! Collect the solar thermal power using low cost, low temperature panels, use a heat exchanger (an enclosed car radiator) to flash the refigerant, and the low pressure multi-cyclinder flexrod to drive the 4 KW AC generator. I'll use a couple or three more car radiators to condense the refrigerant, or maybe come up with a better use for the excess heat.
If I collect that for a few days, and save for a couple of decades for a Tesla, I can really go fast! And not feel guilty! Meantime, I'll stick to my ebike. :lol:
SteveCA
