General_Lee
Big thanks DocDoctorbass said:General lee,
There is few questios here to discuss.
When comparing SLA and li-ion the first major diff is the weight. But we all know already.
The second thing is about the performances: the SLA suffer from Peukert effect ( please search on the E-S there is a lot of discussions already about that.
The peukert effect is a negative effect that the lead acid battery havd with make them to have their rated Ah to vary according to the discharge rate.. and it's not just a question of Ri. the usual lead acid battery are rated at a rate of C/20.. so if a battery is rated 20Ah it will give you 20Ah but at a discharge rate of 1A. If you discharge them at 10A they will give you around 15Ah. But it's not a question of Ri and heat loss at high rate.. it's more chemical and it's a particular effect that Lead acid have.
The real question you need an answer is how many Wh my pack is capable to produce at the average rate i'mm be using it!
In fact if you bought cheat cells from a seller that sell mostly cells for flashlight there is a chance that these cells will not be qualified for med-high discharge rate.
The best action is to buy cells from guys on E-S !.. there is a lot of group buy or guys offering to build pack and that also want to keep their great reputation to continue selling them as well.
If a 8p group became very hot at the discharge rate you tested it mean one thing:
these cells have abnormally high RI (internal resistance). Sometime if these cells are like that and are new it mean that they are counterfeit or original but very old witch make them to have increase of internal resistance, or just rejected cells.
When you want energy for ebike power ( Wh at med-high rate), you need both Ah and low Ri. These two requirement can be obtained with trusted sellers. :wink:
From my experience with the battery you pay for what you get on ebay about battery.
If you ordered battery that does not meet the spec that are displayed on the auction, then you can contact Paypal and ask for help, Paypal are hungry for fee and we all know as well but when you need help to solve an issue they do the job well and you get satisfied in most cases.
Doc
I bought my pack here: http://e-greenmotion.com/ (Ebay name: naama1485) I not bought by Ebay.
You know this place? the guy seemed give a excellent services! but I was wrong.
