Syonyk said:If I understand your modification properly, you're taking a standard two wire (hot, neutral) plus ground setup into a room, replacing the neutral with an out of phase hot (for a 240v difference between them), modifying the other outlets to use the ground as their new neutral, and then tying the ground to that neutral. You've now made the existing ground the neutral, and there is no proper ground anymore.
If I understand this description correctly then my concern is that the ground (safety earth) would be carrying return current/voltage. As long as the earth system for the building is good that shouldn't be a problem, but if it were incomplete or had high impedance you could see dangerous voltages on earthed items like pipework or device casings.
It's something I might be tempted to do in my own home out of expediency as a temporary, one-off event.
