onloop
- Joined
- Jun 24, 2013
- Messages
- 600
This is probably not great "forum etiquette" but I have actually posted this in two places because I wasn't sure if the battery gurus or the e-board gurus where needed to answer my question... Because I can only assume LVC is probably configured very differently depending what electric vehicle/device you use. Such as when your flying an expensive plane as they can fall from sky when there is no power etc.
So to read it on the skateboard section go here: http://endless-sphere.com/forums/viewtopic.php?f=35&t=55931#p833136
So I know there are lots of existing posts & thread & info about LIPO technology and rules to follow when charging / discharging, but I haven't been able to find the exact answer to this:
NOTE: For reference purpose, I am using an Alien ESC on a skateboard with a 6S 8000mah zippy flightmax 30c battery, powering dual 270kv motors.
SO BASED OFF THIS FAIRLY WIDELY EXCEPTED INFO ON LIPO's:
> You should never use more than 80% of your battery (so 800mah of 1000mah bat - leaving 200mah)
> & if the Ideal charging / discharging range for Lipo is say, 3.65v minimum to 4.2v maximum(or 4.1v as some peeps rcm'd)
> And you should NEVER GO ABOVE 4.3V NEVER BELOW 2.7V (i'm assuming for safety reasons)
What should I set my ESC Low Voltage cut-off at?
Some people say (ESC supplier also) 3.3 or some say 3.5 but this still seems very low because at this voltage you are way past the 80% mark & also well out of the Ideal voltage range..... Is this because sometimes voltage can drop down then come back under heavy strain?
So when taking into account the "approximate" info available from these various "Capacity VS voltage charts", such as:
4.20v = 100%
4.03v = 76%
3.86v = 52%
3.83v = 42%
3.79v = 30%
3.70v = 11%
3.6?v = 0%
Should I Set my LVC at say approx 3.75v? therefore hopefully not breaking the 80/20 rule. Or would this cause problems when heavily drawing energy from battery?
But then what the hell is the ideal voltage range referring to then? Because 3.65 is probably like 5% capacity left in the battery, which based on the 80/20 rule will reduce battery life.
Based off the existing information I'm confused? :?
So should I?
A) rely on my LVC set at a 3.75 voltage to obey the 80/20 rule
B) or use a voltage alarm sounding at 3.75 (obey the 80/20 rule) and leave the LVC at 3.3
C) or use voltage alarm sounding at 3.65 and leave the LVC at 3.3
D) or do I need to literally do my own calculations and measure the voltage level at (or record how long it takes in minutes to get to) 80% capacity of the battery energy.
4.20v = 100%
4.03v = 76%
3.86v = 52%
3.83v = 42%
3.79v = 30%
3.70v = 11%
3.6?v = 0%
So should I?
