huntybike said:
1 phase cables to the motor/Agree
2 not sure/ This is the problem there are 3 cables with 3 lines i don't know which one is 3 speed dial.
3 either the speed signal to the tachometer or the brake signal. I'd say this one is the brake signal/ I think speed
4 Main power from the battery. The thinner one should be connected to your main switch (generally the keylock)/Agree
5 not sure/ also
6 not sure/also
7 either the speed signal to the tachometer or the brake signal. I'd say this one is the tachometer speed signal/cruise signal i think
8 Hall sensors/ agree
9 Throttle/I have no idea
10 three speeds mode switch/i don't know which is which
11 is a cable for testing purpose. You can use it to check if the motor and controller are working once power, hall sensors and phase cables are connected (1, 4 and 8). Do not connect it for normal operation./agree
12 Power supply to your antitheft alarm (if you have one)/Agree
For now just connect these ones:
8 Hall sensors
9 Throttle
Those are the only ones necessary to run the scooter. I'm very confident 9 is the throttle, this color combo was used on pretty much every controller I've seen so far. In case you aren't sure, just use a multimeter and check the voltages. Red should be around 5V, black should be ground and green should be the signal. There's not much risk to connect it to your throttle, even if it's not the right one.
The other cables are just gadgets, you can figure them out later by trial and error. The 3 speeds switch is easy to figure out (just use a paperclip and shunt one wire to the other until you find which one does what), the brake signals are pretty much useless and somewhat annoying when you drive so I wouldn't use them if I were you, the speed tachometer is easy to find, (just plug a voltmeter between this cable and a ground, spin the wheel full throttle and see if there is a voltage change), and the other wires don't seem to serve any useful purpose at all.
My 2 cents: if you want your ride to be as reliable as possible, try to avoid using all the gadgets. On my builds, the only things that are connected to the controller are the throttle, the hall sensors, and the power wires. Any other stuff is just an added risk of failure, which will make you push your ride back home at some point.
