GCinDC
Nice! Video of how quiet it is?
GCinDC said:Nice! Video of how quiet it is?![]()
recumpence said:Here is the video;
http://www.youtube.com/watch?v=GQV0UzV5qTM
I purposely used my wife's camera to record this video because it is hyper sensitive to high pitch noise. What you hear in the video is actually far louder than the sound in real life.
Under acceleration, you can hear the motor. But, when up at speed, it is pretty much silent. Bear in mind, every time the trike is in sight, the motor is running. It is not coasting at any point in the video other than when you hear the front brake rotor vibrate.
At the end of the video, you can hear the rear tire spinning as I turn around and approach the camera.
Enjoy!
Matt
recumpence said:That is actually bad for the rotors. The way the center portion of the rotors is setup, that can cause the rotors to warp under hard braking. So, I have not tried reversing them yet.
Arlo1 said:The oem harley stuff is big and heavy!!!
And its all to big for ebike stuff.
Yeh but the factory casting is not that perfact and the belt cogs are HUGE and the belt would rob 1-3 HP alone kind of a waste for e-bike stuff!E-racer said:Arlo1 said:The oem harley stuff is big and heavy!!!
till you take the lathe and mill to it...
Polychain Belts:Matt said:---The pitch is 8mm.
---The tooth profile is Polychain, not the typical HTD.
---The belt style is Contitech Syncrochain Kevlar cord.
---Ratio is 3.07 to 1 (26 tooth front, 80 tooth rear).
My reasons for using these particular components is multifaceted;
First, even at 8mm pitch, 15mm width, a HTD belt would be near its limit with a 3220 motor. This belt and tooth profile is WILDLY over speced. This particular belt in a 40mm width is used as a jackshaft to track belt on 400hp supercharged snowmobiles! So, this application is child's-play for it.![]()
Sprague clutch:Matt said:----The freewheel up front is a Sprague oneway style clutch rather than a standard clicking freewheel.
---Second, the Sprague clutch is silent and does not have any backlash like a normal freewheel. This allows for silent freewheeling and silent engagement.
recumpence said:....So far the sprague is fine. These are designed to run in very unforgiving environments (like gravel conveyors)....
recumpence said:..So far the sprague is fine. These are designed to run in very unforgiving environments (like gravel conveyors).
