safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Cost might be a factor. Efficiency might be a factor.ZapPat said:I see your idea as actually being a chain of totaly seperate PWM circuits, one for each cell. This necessarily implies seperate PWM controllers, FET driver(s), FETs, inductors and capacitors for each cell. As others have noted, this would be most likely be less efficient than regular battery PWM, but mostly it would be VERY very complex in implementation and fabrication.
But I'm focusing on the concept at this point.
The very fact that PWM can take a voltage and current and translate it into a lower voltage and higher current means that you have the freedom to maintain a constant high current across the whole pack even when some of the cells are actually only contributing less than others. It's that weird "fluke" of behavior that captured my imagination and makes this idea interesting.
The PWM "current multiplication" effect has been staring us in the face for all this time and it could possibly be the cure for balancing...
