daveo12345
- Joined
- Nov 27, 2019
- Messages
- 16
Hello, first post. I recently bought a brand new a2b velociti. The bike seems to be similar to a2b Metro and a2b hybrid overseas.
The bike was missing the battery. I've made a very nice battery pack 36v using greenworks 40v batteries and diodes to protect each. However, I've a few questions.
1) The a2b velociti seems to be different in that it only has the rear 1 battery, no frame battery. Can anyone confirm for sure? The manual does not reference a frame battery
2) The battery plug pinouts are discussed for the metro in other threads. However, this is one with 6 not 5 pins. I'm guessing the small pin next to the plug "key" and the pin opposite are used in the bms and not necessary to get the bike going?
3) I found the "switch module" in the frame....which i am guessing is not quite a controller. The switch module inputs the brake cutoffs, throttle, and passes 7 wires to the wheel assembly via 1 big wire which really contains 2 thick (Red black directly from battery) and 5 small wires control (yellow / blue / white/ and two others) via another small plug connector. I am guessing the 5 wires are control wires from the switch module which looks like a controller is in fact just a switch module and the real controller is in the hub? If so, there is a youtube of a guys shorting the miniplug on a a2b hybrid, causeing the powered wheel to run at full throttle.
could i add a separate controller by using the second controller, passing motor output of the controller on the existing thick wires to the motor, shorting the proper pins on the OEM motor miniplug, and get away with not disassembling the hub? If the 5 (really 7 counting power) wires going to the motor on the oem are 1. voltage for power 2. ground 3. brake cutoff (compost meaning l/r) 4. throttle voltage and 5. unknown (TBD) I should be able to provide voltage on perhaps 1 and 4 and get full power from the red and black and if the external controller limits this, thus the external controller is in control and i did not have to disassemble the hub?
