lnanek
Power poster
I don't think there's any soldering there. I use a similar Sunkko battery equalizer model:
The green connector block is a bunch of screw down terminals. So you stick the bare end of a wire or ferrule in each and screw down the screw. The other end of his wires look like a typical JST connector and pigtail. For example:
Or if he created the pigtail himself from a set like:
ebikes.ca
You crimp a pin on the other end of each wire and stick it in the connector. So no soldering. You could remove the green block and solder directly to the PCB pins, I suppose, if you really wanted to, for the highest A balancing current with the least connection heating.
Then his battery seems to have a typical JST connector for the balance wires going to each p-group.
Bag of JST Connectors
Bag of Small Plastic Inline Connectors (12 pairs) used for throttles ebrakes Cycle Analyst etc.....
