hey guys i finally finished reading all 21 pages!
i was working on a pre-charge/anti-spark circuit for some time and it wasn't exactly perfect so i decided to look in the place i should have looked at in the first place, ES forum!
my setup is a 12s (50v) lipo that would be running at a MAX of 50 amps. however i also need to power a separate receiver with a 5v rail.
The circuit i was working on my own was using a separate resistor to first charge the caps and then the mosfet would turn on after 3s. i did the time delay for the mosfet using a 555 timer delay circuit. i tried using capacitors but they weren't working for some reason. this is the circuit.
the timer pin is pin3 connect to "source" since i need to connect the 2 negative rails for the gate to open (using a different positive rail for the gate). i could have turned on the GATE by adding another relay and put pin3 to the relay.
here is that circuit:
my circuit some times worked and other times it acted funny (gate was open even when no positive voltage was applied).
however after reading some of these posts it looks like i could have just blown the fet.
i want to use one of the circuits that you guys approve as i know very little about this stuff. Fechter posted this schematic a while back but im not sure if anybody tried it and it worked or if it was suppose to work in theory. here is the schematic:
i have 2 issues:
1)why do i need a 12v zener if i am using a 9v battery? the voltage wont go past 9v. (in my case 5v)
2)i don't have a on-on switch so can i just put a 1M resistor between gate and source permanently? i think izeman did this in his switch and it worked fine:
if i didnt explain it good, sorry, let me know and ill do my best. thanks for the help.
