spinningmagnets
100 TW
I have to agree with Fechter on this. If there is any way to avoid a reduction, you should take it. I would suggest that my experience with friction drives counts for something. Running two motors against the rim is a viable strategy.
One oddity about friction drives is that...they provide the same road-speed regardless of the diameter of the tire you mount them to. In fact, large diameter tires with a friction drive have better hill climbing, compared to a smaller-diameter wheel (the opposite of a hub-motor).
Kepler started out with a single 50mm RC motor, in order to make his kit as light as possible. However, they suffered heat issues on hills, the one place where E-assist was most needed. Once a manufacturer began making a low 149-kV motor in the more robust 63mm diameter RC motors (more copper mass), that became the default choice. The larger 63mm diameter often influenced owners to choose the lower-speed 5S battery packs (18-ish volts), instead of the common 22V 6S.
You, on the other hand...run drive-rollers against the rim, which can be a separate diameter compared to the motor-shell diameter. In this case. I would say that...if you can source a low-enough kV, using two 50mm motors would work. (2X 50mm is better than 1X 63mm)
The only other issue I would warn you about is...the drive rollers need to sit on a shaft that is supported on both ends. Your current configuration may last a long time, but...it is only a matter of time before the shaft breaks, due to a slight bending while running thousands of RPM's.
