DeathBlade
- Joined
- Oct 18, 2008
- Messages
- 111
I got this idea to make a four wheel ATV- eske ebike like Seaways centaur prototype but with the ability to be pedaled probably with a 5 speed setup using four hub motors( maybe 408's ?) on 20 or 24 inch wheels. It would be great I think, but the huge problem is transfering the rear wheels I have a idea using shaft and chain setup,using a 5 speed cassette and single speed crank. The cassette would be mounted on a shaft set in two pillow block bearings along the axis of the rear supsention pivot, on the ends of this shaft would be two 20T sprockets turning two 22T sprockets the the hubs for some extra gearing(its a ATV bike it needs torque!) But it to has a problem. For it to work it would require flipping over the right rear hub so the sprocket thread are pointing inside and then running the hub in reverse, is that possible? I thing my paint diagrams explain it better. So any thoughts?
Edit: I made a order to TNC for a 36v YK42 and a thumb throttle on saturday and I got it today and I got a foot throttle, I called them up and they said opps, "If you buy another thumb throttle we'll put a return lable in the box and you can ship the foot throttle back to up and we will refund your money when we get it" This pisses me off! what should I do?
