This is the variation I was imagining a few posts back after seeing this great idea you showed. The roller would sit inside a squared channel, and the triangular side plates would also act as the bearing retainer plates.
I have one of the SDP-SI "shaft-loc" expanding bushings. The roller shaft (1/2" dia) would have the clutch-bearing (outside the sideplate) and the motor shaft would have an adapter sleeve to beef up the shaft dia (10mm or 8mm) to 1/2" so the shaft-loc could attach the motor shaft to the 5mm-HTD pulley.
http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=8491&start=15#p301680
In spite of the obvious added complexity and cost, it allows the use of the higher kV 8mm-shaft motors (300kv-400kV), and that is somewhat of a sweet-spot for using a single 6s LiPo brick (22V, 5800-mAh, 30C).
Once thats in place, there are over twenty 5mm-HTD pulley diameters that will work, allowing anyone to choose exactly the top speed they want. or, to later change the top speed (quite easily) by simply purchasing a third pulley to swap in. These motors are small, but the direct-drive I am working on has the motor poking out to the side, and your idea puts the motor squarely in the center of the drives mass.
The stems (used as the mount) can be angled up or down, and can be bought long or short. If a customer wanted to change the drive to a different bike-frame, there are 38 pages of bike stems at Niagra to allow a rapid, cheap, and easy re-fit.
If you decide to make something similar to this drawing, perhaps make the belt-side plate wide enough all around so that later you can add a belt-cover? then, at that point you can trim off the excess.
It may even be possible to use an aluminum channel (4" wide, 0.250" wall thickness), with the part that connnects the two side-plates being on the back of the drive?
![BeltedFriction.jpg BeltedFriction.jpg](https://endless-sphere.com/sphere/data/attachments/26/26000-15209ad4d92655615c9580cc04ee474a.jpg)
