xyster
Jozzer said:Sounded quite normal to me Knoxie, those americans must have funny ears or something :lol:
I think you're onto something there. I'll need a Brit-aware ipod-like universal translator.
dermot said:knoxie said:Hi
Shiver me timbers, isnt it speak like a pirate day yet? .... me harties!
Knoxie
Not quite yet, you scurvy knave:
http://www.talklikeapirate.com/
September 19th.
xyster said:I think you're onto something there. I'll need a Brit-aware ipod-like universal translator.![]()
recumbent said:Oops, just saw in the picture the six holes for disc mounting, my bad
forgot to look before I spoke. Thanks for pointing that out.
Jozzer said:I have, and it just fitted right on! It was the stock disk for the KMX (made by winzip), and is the same size as the stock disk off an old mountian bike I have too. My guess is it is a standard fitting, and your LBS is missing the most used disk!
deecanio said:mine seemed totally standard?
i took the old disk from my 26" wheel and just screwed it straight onto the puma?
Ian, do you have any pics of the problem?
Herrsprocket said:Nice pics, helps alot. So where'd you get the adaptor? Coming from a Chinese factory you can get a 35x1mm thread for the hub thread adaptor or get the standard western size of 1.375x24 tpi thread pattern. If you can screw on a regular freewheel ( typical USA or Euro style, Shimano or such), and it goes on without binding, then you have the 1.375x24 tpi size. And that would be good, well, good for all us interested in that sort of thing! Oh, and by the way, the standard bolt hole diameter spacing for the rotor mount is 44mm, straight across, center to center. So, supplier?
Jozzer said:Yes, those holes are more widely spaced than mine. They would be great for mounting a sprocket in order to use the motor as a BB drive! (they seem perfect for the job, with the extra freewheel and all)
The holes on mine are drilled into the motor casing as yours, but spaced much closer. Mark did tell me that some of the BMC needed a thread-on adapter....
Never mind the velo, would be nice to race each other on the KMX's round a fun track! (hmmmm....thoughts of renting goodwood for an afternoon next spring for a community ebike racing day!)
