Rolling resistance in my brushless front wheel mounted Ateoma hub motor seems pretty high. After a lot of searching I found at Renaissance Bicycle company a Crystalyte Motor FAQ that covered the topic (text below). What I am wondering is this common to all brushless hub motors? It seems odd that we have freewheel hubs to allow the rear wheel to turn forward freely when the tire is moving faster then the sprocket cassette, but for non regenerative hub motors it seems like you just get a braking effect unless you have your power turned on. Are there ways of fixing this with the Ateoma or other brushless hub motors? Are there any manufactures that make freewheeling hub motors?
Part of the reason that I am asking is because I recently ran out of battery power about 3 miles from home. I live in a very hilly part of southern California, so it was about 2.5 miles uphill pedaling for me. This is the same stretch where I have seen several experienced riders have to stop to catch their breath. Adding a lot of weight for the hub and the battery/controller etc made it a tough ride, though I'm happy to say I was able to pedal the whole way back, with my wife laughing at me for not charging up my battery! :? Anyway, it just seems like part of the challenge was having to overcome the inertia / drag force in the hub, which seems like a poor design.
" I just got my motor but can barely turn the axle there is so much resistance, is this a defective unit?
No, with any direct-drive motor there is significant drag force required to turn the hub due to the strong interaction between the magnets and the stator. With the Crystalyte 400 series motors, this is about 0.4 N-m, while the torque to turn the axle of the 500 series is closer to 0.7 N-m. That is more torque than most people are able to apply just with their fingers turning the axle. However, if you mount the wheel on the bike and spin it, you will see that the wheel can still turn more or less freely. If you give it a whirl it should turn 3 or 4 revolutions before coming to a stop. The drag force caused by these hubs is comparable in magnitude to the rolling resistance of the tires on a regular mountain bike."
