Apologies if asking obviously stupid questions.
I've recently popped open a generic chinese ebike kit with a hope that I might be able to tweak some settings.
If not, that I'd be able to replace the controller +/- display and salvage the battery.
It's the EZ Rider kit, that comes with the battery and controller in a hard case.
The PAS levels seem to change the cut off speed, and deliver too much power for comfortable cycling. The power seems to increase with cadence. Probably a good thing when starting from stationary, though very annoying when changing gears as you speed up. There's power when you don't need it, and none when you want it.
I was wanting something that limits power based on PAS level, and ramps down as the cadence increases. Such that there's a bit more power delivered when starting from stationary, and when downshifting gears.
Was wondering if I could change the display, or if I'd need to just get a new controller and display.
The current display looks like this one... M15 Ebike Centre Control Panel - To7motor
Any ideas?
Many thanks!
Any ideas?
Many thanks!
