APL
- Joined
- Aug 6, 2018
- Messages
- 1,113
First post on the ES, but certainly no stranger here. I want to thank all of you for your experience, expertise, and help in getting me through these builds, I couldn't have done it without you! Thanks! You Rock!
The knowledge enclosed within these pages is is simply phenomenal!!
I decided to go in a little different direction on this bike, tentatively a leisure bike, technically a comfort cruiser, and a bit of a lazy boy bike. I have not seen any mid drives with the motor mounted in quite this fashion, so I decided to experiment with the idea. It allows for a fairly quick motor change with a good solid mount, and a direct drive to the rear wheel, with a low, centralized weight.
I've been test riding it for almost two years now, and the only problem I've had is not wanting to get off when the ride is over! I'm thinking that it's going to take something like this to lure people away from their cars. We would need a bike at least as fun as driving a car, if not more so.
This is a 'boots and bluejeans' bike, just sit down, pull the throttle, and go. Theres no need to pedal,.. but the option is always there.
I'm wanted something a little more user friendly, that anybody can understand and work on, and can be repaired at home, using conventional bike parts, that won't be obsolete in a few years.
It's still experimental, but I was hoping perhaps others might take this design a step further, and improve upon it. I'd be happy to post the plans, dimensions, or show the build.
I tried to design it with the best handling, low center of gravity, and creature comfort in mind. It uses a motorcycle solo seat with an air shock that works surprisingly well, the choices in seats are endless, and the suspension shock can be dialed in to suit the rider. The 56cm headset hight sets the bars up high enough to take the pressure off the hands. Something that people with wrist problems, (like me), can appreciate.
And being able to put your feet down at a stop light is reeeal nice,.. and a safe way to stop.
It only uses some of the gears in back, as the big Crystalyte motor has plenty of power. It doesn't seem to care what gear it's in, the take off is all the same, except in the highest gears. I usually leave it somewhere in the middle, where at full throttle, it cruises at a street legal 20mph. Theres no need to shift,.. it goes straight up to 20mph in a single twist of the throttle.
With a 17T drive cog, it has no problems going up any hill, and draws about 250 watts on the larger ones at about 18 mph. On the flat, it draws about 100 - 150 watts at 20 mph. With the current battery set up, it will go close to 25 miles, at around 20 mph, and thats with all the country hills and wind. It has 'no hands' riding stability, and acts like it's stuck to the ground with a magnet. It is an amazingly stable ride with a 68 degree head tube and a 52" wheelbase. The BB hight is about 9".
I solved the drive cog problem on the mid drive motor's freewheel side by using a rear hub disc adapter and running the six bolts down into the motor face. By using two adapters, I was able to screw in a BB cup, and instal a freewheel onto that for the crank drive. The cranks are 115mm for toe clearance, and a lower BB. No problems with any of that yet, but then I hardly ever use the cranks anyway. Like I said,.. it's a leisure bike.
Obviously the batteries don't supply enough power to feed this big of motor, mostly it shows that the biggest motors can be used in this design. The next version, V3, will have a more reasonable size motor in it. And perhaps a Shimano internal gear rear hub. The Zee short cage-clutch der is needed to keep the motor from pulling the chain over the cluster cogs. LOTS of torque.
I've chosen drill packs to power these bikes because they have a three year warranty from a five star company, can be replaced overnight from a local store, and can be charged in one hour. Plus, the cassette design is safer, because even if one pack should fail, the others will keep the bike going safely until you get a replacement. Drill packs are probably the safest batteries on the planet, and at the leading edge of battery technology.
Eventually, I'd like to use some solar panels on the shop roof, have them charge a 12v battery connected to an inverter,.. that powers the chargers. Then the whole thing will run off of free, clean solar energy.
Having said that, the design will adapt to most any battery set up as well. I just don't like the idea of waiting overnight for batteries to charge, or being able to ride only once a day. But there are advantages and disadvantages either way.
For this one I'm using six 5ah 20v units, three sets of two, with a switch on each set, for 40v at 15ah. 40v may seem small for an E bike, but this is a mid drive, and gearing makes all the difference. The motor is geared down roughly three to one with the 17T drive cog, giving it three times the torque of a rear hub motor. This thing has power to spare. And since it goes 30 mph, it really doesn't need any more than 40v.
The lower the voltage, the more aH you get from a battery pack.
I use a small digital volt meter for a gas gauge. At 41v (full charge), it's full, and at 30v it's empty, 35v is the turn around point.
For the next version, I'll be using four of the new 9ah battery packs, if I can figure out how to put them in there without hitting anything. They have a greater watt output for more torque and will increase it to18ah. I'd like to use six, for 27ah, but the look may be a bit much. It doesn't need any more power, but they say power corrupts,.. and I think I've been corrupted!
